I have on/off switch in hole #2. Hole #3 is empty and the push/pull rod for the belt pullye is tucked close to the left brake peddle. Actually a little too close, sometimes when I stomp on the brake peddle the belt pulley gears grind. My '41 H has a shutter control but the mounting plate doesn't quite look like Seth's and there is no second hole where he has his on/off mounted. I don't have a picture of it though.
I'm tempted to keep the tractor close to orginal, but really dislike the big starter button (mounted on the bottom of the column on a '41) and am considering installing a 300 IH off/run/start ingintion key, just not sure where to put it, i think it needs a bigger hole than the on/off. Sacrilegious to replace on/off switch and starter button with an ignition key?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
