Re: 400 vs 560
Posted by RPM1941 on January 17, 2011 at 11:52:23 from (173.25.70.110):
In Reply to: 400 vs 560 posted by running in the red on January 16, 2011 at 17:34:16:
560 was same basic as 400-450, these evolved from the M-SM-SMTA, rear axle cap gaskets, rear frame top cover gaskets, split gaskets & axle housing mount gaskets all same, gears interchanged somewhat, differential gears & cross were same, bull gears & brake shafts didnt, in fact early 560 had 450 bull gears that were recalled & changed, these are the tractors that serial plate was a diamond triangle added. Axle bearings & pinion brake shafts upgraded to later serial 560. Transmission somewhat common.
