Re: cub water in oil
Posted by Andrew Z on January 17, 2011 at 16:07:11 from (64.252.112.28):
In Reply to: cub water in oil posted by questadg on January 17, 2011 at 15:59:53:
I would pull the head and replace the gasket, use a copper coat product on the gasket (spray on). Make sure to re-torque after running a time. You can coat the bolt threads with some RTV if you would like.
Andrew
