Re: 400 coolant in oil
Posted by Denis in MI on January 17, 2011 at 18:12:15 from (107.5.98.114):
In Reply to: 400 coolant in oil posted by Denis in MI on January 15, 2011 at 16:59:07:
I took the head to the machine shop today and the owner was very knowlegeable of Internationals and upon inspection we found that the washers that go on two of the head studs had not been used when it was installed the last time which allowed the bushings on those stud holes to sink and the head to lift causing the coolant leak, whicj in turn caused the engine to sieze. He is going to grind the valves, magnuflux, and mill the head back true and I should have my W-400 back in action.
