Re: Farmall M Sputtering
Posted by The Red on July 10, 2000 at 11:47:18 from (206.246.187.2):
In Reply to: Farmall M Sputtering posted by Lance on July 10, 2000 at 11:14:54:
Lance take a wire and start spark testing. Check the hot side of the coil switch against the frame. Then check the switched side to the frame. If that is good then check for spark on the inbound side of the coil. If that is good, check the output side of the coil against the frame. Then check at the distributor. I bet you find your problem somewhere in there.
Post A Followup
: Re: Re: Farmall M Sputtering
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
