Re: C Farmall runs high RPM'S when started cold..
Posted by Brownie 450 on January 17, 2011 at 18:48:26 from (66.43.241.198):
In Reply to: C Farmall runs high RPM'S when started cold.. posted by stevecl on January 17, 2011 at 14:01:09:
Our A had this problem & we just put the throttle lever to the lowest setting when it was shut off for any length of time. We figured that ice was forming in the needle bearings on the "output" shaft. Eventually, we had to replace the needle bearings because of rust.
