Re: 300 acres corn soybeans, what HP tractor
Posted by glennster on January 17, 2011 at 19:10:09 from (99.90.9.153):
In Reply to: Re: 300 acres corn soybeans, what HP tractor posted by arod on January 17, 2011 at 18:31:53:
sounds like your bins have stir-rators in them, 2000 bushel wont be enough storage for 300 acres. a chisel plow, field cultivator with a tine harrow, and possibly a disk. if you get bad soil compaction, you will need to fall chisel plow, then hit it with a field cultivator in the spring. rare if anybody cultivates. if you are going to conventional till, get a rotary hoe also. if the ground crusts over after planting, you may need to run the hoe to get the crop to break thru. keep an eye on what the neighbors farms are doing as far as tillage, your county extension office is a good source of information also.
