Re: Farmall BN Will Not Start When Warmed Up
Posted by old on January 17, 2011 at 19:57:14 from (4.245.7.86):
In Reply to: Farmall BN Will Not Start When Warmed Up posted by Rusty Knuckles on January 17, 2011 at 19:01:12:
Well #1 to tell if it is 6 volts or 12 volts count the number of cell caps/holes it has. If you have 3 it is 6 volts if 6 you are 12 volts. Sits for and hour and then starts again sounds like a coil going bad. Both a distributor and a mag have coils just a distributor has one that has a wire running from it to the distributor cap and on that coil is a wire that goes to the switch and has battery power going to it and a mag has an internal coil and no battery power going to it and may or may not have a wire hook to it going to a shut off switch
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
