Re: Case IH 8420 Round Baler
Posted by Bill Lisbon on January 17, 2011 at 21:03:09 from (69.89.163.218):
In Reply to: Case IH 8420 Round Baler posted by Randy2 on January 17, 2011 at 14:33:03:
The 8420 was a pretty good baler. Check the belts for wear. Check the rollers for loose bearings. The finger wheels at each end of the pickup were known to be a trouble spot, and they are big bucks to replace. Round balers don't have knotters they just wrap the twine around the bale. The hydraulic wrap uses a small hydraulic cylinder to move the twine arm putting the twine around the bale. You need to have 2 remote valves on your tractor to use this.
