The most likely place is the "anti-hunting" spring. There is an acorn nut on the top?? I think, of the governor housing. Under that nut is a "cylindrical threaded fastener with a slotted end" with a lock nut on it. The "fastener" is drilled out for a little spring about the size of one from a ball point pen. Moisture condenses in the spring and freezes, the spring cannot move, and holds the throttle open. I dry the assembly out and pack the cavity with grease, that keeps the moisture out for a while. If you only move the lock nut far enough to release the "fastener", you can use that as a mark for re-installing and adjusting the "fastener".
"Cylindrical threaded fastener with a slotted end"=s*c*r*e*w. Potty mouth filter got me the first time I tried to post this.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
