Re: breaking a motor loose
Posted by Jim350 on January 18, 2011 at 07:57:02 from (72.228.48.9):
In Reply to: breaking a motor loose posted by sunaewayha on January 18, 2011 at 07:50:49:
I mix up a witches brew of PB Blaster, Liquid Wrench, ATF and Acetone along with a bottle of Rust Buster and keep putting it down the spark plug holes for a month. If that doesn"t free it I take it apart.
Don"t forget to remove the oil drain plug so the brew does.t stay in the oil pan.
