Re: breaking a motor loose
Posted by Andrew Z on January 18, 2011 at 07:59:32 from (64.252.115.246):
In Reply to: breaking a motor loose posted by sunaewayha on January 18, 2011 at 07:50:49:
You can start with putting ATF / Kero / Diesel fuel into the cylinders. Let it set for sometime and give it a hit with the starter of hand crank for some time. If that does not work after sometime then remove the head and either pound the pistons with a oak block down. If that does not work then you can just pound the cylinders from the bottom up and out and have them pressed out.
Look in the archives there are 100's of post on this topic there.
Andrew
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
