Re: Farmall BN Will Not Start When Warmed Up
Posted by Dave from Texas on January 18, 2011 at 10:04:24 from (66.249.124.2):
In Reply to: Farmall BN Will Not Start When Warmed Up posted by Rusty Knuckles on January 17, 2011 at 19:01:12:
I had an H that did the same thing. As long as i didnot let it die it would run strong all day long. If it died I was stuck. My problem was that the rotor was not the right one for the mag. The timing would move just enough to keep it from starting. So I would recommend you check to see if it is good and tight and then check the timing.
