Re: Super M Hydraulics
Posted by john d on July 10, 2000 at 14:04:59 from (206.141.74.34):
In Reply to: Super M Hydraulics posted by K. Johnson on July 07, 2000 at 09:49:15:
Okay...if I'm understanding you correctly, you can do PART of what you want to do. I'm a little confused by the power steering comment, but for now I'm going to assume that it is NOT plumbed into the hydraulic system you're using for the loader and 3pt hitch. I'm even more curious how you are using both a loader and a 3pt hitch if you don't have live hydraulics. (I've got both on an M without live hydraulics, but I can only use one at a time!) If you have the basic "lift-all" system (NOT LIVE) you do indeed have 3 ports, but NONE of them is a RETURN port. They are ALL pressure ports. I would suggest the following: Install a ball-type shutoff valve in the line that has the T fitting to the loader. This will let you lock it at whatever raised height you wish to keep it out of the way. Install a similar shutoff valve in the line to the 3pt hitch, allowing it to be kept at a stationary height. Run the line to the baler cylinder from the remaining port on the left side of the tractor. This will let you have power to lift the baler pickup without moving the loader or 3pt. hitch. The single-acting (non-live) lift-all system has all three ports plumbed for pressure when the control lever is pulled. The right-side and front left ports receive pressure first, and at the same time. The left rear port is a "delayed action" outlet for lifting the rear gang of cultivators. When the control lever is pushed down to the first detent position, pressure is released on the front ports. Pushing it all the way down releases pressure on the back port. Oil flows back to the reservoir through the same line it came from. NO SPECIAL RETURN LINE IS NEEDED. Of course, all bets are off as to this working if you have some sort of hydraulic system other than the basic pre-live, lift-all, belly-pump arrangement!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
