Here is some good info from an Interstate Battery Tech: Storing a battery in cold weather is easy, if the battery has removable caps make sure the water levels is above the plates and clean the posts if necessary. Hook the battery up to a good automatic charger sized to the battery capacity and rated for the type of battery you have. Right after the battery is done charging check the water level and add distilled water to 1/8” below the vent wells if necessary. Allow any water that was added to mix with the electrolyte then check the specific gravity using a hydrometer, a fully charged battery should be around 1.285 specific gravity. The battery may need to run through another charge cycle if a lot of water was added. Storing the battery in a cool location will slow down the self discharge but it will still be necessary to recharge every other month or use a maintainer charger after the battery is recharged.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
