It's easy to pull the engine on an A. I unbolted the front wheels and steering from the engine and rolled it out as an assembly. You need to support the tractor at the drawbar since the tractor will tilt backwards when the engine is removed. The engine has dowel pins and may be difficult to remove even with the bolts out. It will be easier if you have a helper and once you get a little crack between the engine block use a big screwdriver to pry. You will need a good engine hoist to lift the engine. I marked all the wires so I knew where they belong and ended up making a new wiring harness. Hal PS: I used a little lubri-plate on the dowels when reinstalling the engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
