If I had that tractor I would no matter what fill the cylinders with ATF. The reason for that is so the rings will free up and also to help clean off any rust that will be on the cylinder walls ad also stop any more from forming. You say baling what did you have a baler with its own engine since I know an A does not have the power to both power a baler and pull it also. Years ago I would use my B to test a baler because of the lack of power so as to be less likely to brake something if the baler had a problem. The B would spin it ok but if you tried to feed it with hay pulling or sitting still the B would stall out for lack of HP needed to work a baler
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
