Re: splitting a farmall 'a', at transmission
Posted by gene bender on January 18, 2011 at 20:43:39 from (67.55.227.196):
In Reply to: splitting a farmall 'a', at transmission posted by neil p on January 18, 2011 at 11:50:22:
Ive done it several times but i have casters that bolt to the tractor so i can roll it apart. You need to brake line.When you get it apart enough take out the tapered bolts on the u-joint. Do this as soon as there is room that way you wont have a problem getting drive shaft back thru the clutch. Remove the pedal guard so you can unbolt the clutch and left brake pedals as they will stay with the bell housing. I can do it in less than two hrs but i do have casters to let both assys roll. Dont forget the seal also
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
