Re: breaking a motor loose
Posted by John A. on January 18, 2011 at 21:48:48 from (76.1.122.180):
In Reply to: Re: breaking a motor loose posted by teddy52food on January 18, 2011 at 17:40:30:
teddy, I do not dispute your word on the A having wet sleeves! he asked how to Break Loose the pistons from the sleeve!
I will still bet the pistons will come out better after a burning for the sleeve will expand from the heat, thus seating more tightly in it's place, breaking loose the rust that has seized up the piston, then letting the piston be driven out. One can always drive the piston out the bottom, and let the lip help hold the sleeve in place, or drive out from the bottom and let the sleeve and piston come out together, and let the work can be done on a work bench and then a press.
What I do not Understand is there is an Easier way to break loose a derelict engine with fire then a 4x4 block and hammer.,,,,,,,,,,,
Not go to the 4x4 block and hammer then, then hammer and chisel, then torch. As I hear most of the time. Just My opinion here!
Later,
John A.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
