Yes, The one's I've seen cost a little more then the 12 volt versions, but can't say I looked very hard. When I was at one of my remote properties in Northern Michigan, I needed a half-dozen 12 volt maintainers. Locally, the only ones I found were Schumacher brand - 2 amp with a 6 volt and 12 volt selector switch. I didn't need the 6 volt function, but I was n a hurry to leave and did not have time to order something cheaper on-line. I don't recall the model # but both Advance Auto and Walmart had them. Has a 1 or 2 amp selector switch and a 6 volt or 12 volt selector switch. They cost around $24 each.
I've got a Ford F250 diesel truck (with two batteries), along with a backhoe, two tractors and a dozer that sit in MI all winter, locked up. Thus the need for the maintainers - or the batteries would get ruined.
I usually buy my 12 volt maintainers on-line for $15-$18 each.
I see Schumacher know shows a 6V-12V maintainer a little then the ones I got. This new one has automatic voltage sensing and a 2 year warranty. I suppose it costs more also.
Scuhmacher model XM1-5 . 1.5A 6/12V CHARGER
Description: Fully Automatic Microprocessor Controlled Unique automatic battery charger maintains both 6 and 12 volt batteries keeping them at full charge using float-mode monitoring. Perfect for charging small batteries. Great for maintaining small and large batteries kept in storage – motorcycles, classic cars, RVs, boats. • 1.5 amp charger and maintainer. • LEDs indicate: Charging, Charged and Trouble. • Automatically switches from Full Charge to Float-Mode Monitoring. • Quick-Disconnect Harness – Snap either connector into place in seconds – Use the 50 amp clamps or permanently attach the ring connectors…great for hard-to-reach motorcycle batteries. • Reverse-hookup protection. • Auto Voltage Detection – the charger automatically determines whether the connected battery is a 6 Volt battery or a 12 Volt battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
