6 volt is the simplest. to assess the situation, use a jumper cable about 8ft long with 4gauge wire in it as one of the cables to see if this increased resistance will slow the starter using 12 volts. If it does, then (short of building a long battary cable to kluge it together) there are two options. Use a 6 volt battery and convert your alternator (or generator) to 6v. Have your starter motor converted to 12volt operation. (a newer series delco starter might be retrofitted to the same drive) Good luck. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
