Re: Power steering until from a IH-350 easily connect to ...
Posted by Wardner on January 19, 2011 at 12:04:15 from (4.154.254.23):
In Reply to: Power steering until from a IH-350 easily connect to a H? posted by Yooper Farmall on January 19, 2011 at 11:01:20:
third party image
third party image
The factory Behlen is not exactly like the aftermarket Behlen. The input shaft for the former is about 4" long. The one in the picture is around 1' long and is threaded for the steering wheel nut. Don't think anyone has put a Behlen under the hood of a H. Despite how others feel, I think the PS actuator should not be hidden anyway. I like the look of that attachment where everybody can see it.
So you will have to whip out the welder, make a coupling (or two), plus find a bracket. And both the Charlynn and Behlen will need a power source.
