Re: Trans/Rear End Noise in my C (Video)
Posted by gene bender on January 19, 2011 at 14:21:27 from (67.55.227.196):
In Reply to: Trans/Rear End Noise in my C (Video) posted by Faster346 on January 19, 2011 at 14:08:50:
Probably had some moisture in the tranny and it froze and busted the oiler gear. You need to split at the tranny and remove the top as its on the bottom shaft so ya gets to tear the tranny apaart. If you dont use the pto you dont need it anyway as it does throw the lube around to get into the valley that leads to the pto belt pulley assy.
