826D over haul 358 cid
Posted by Icuby on January 19, 2011 at 15:51:57 from (71.7.27.25):
Doing an in frame o.h. on this. I.T. manual says sleeve protrusion should be .003-.005. How critical? Have two that are running .005,other 4 are approx. flush. Shims are avalable[approx.$20.00 per shim]. can multible shims be used per cyl sleeve to reach protrusion specs?
Thanks
