Re: Super H Low Oil Pressure?
Posted by Bob M on January 19, 2011 at 17:44:48 from (67.240.171.41):
In Reply to: Super H Low Oil Pressure? posted by MWZad on January 19, 2011 at 10:26:04:
My '53 SH had the same problem when I acquired it. Cause turned out to be a worn oil pump cover and a partially blown out cover gasket.
I removed the wear marks on the gear side of the cover with careful sanding with 160 grit paper laid the on a sheet of plate glass. Then when reassembling I used a new, thinner cover gasket. Now oil pressure right where it should be even when the engine is hot.
