Re: Not a IH but hopefully some ideas.
Posted by clint s on January 19, 2011 at 19:13:19 from (24.92.241.43):
In Reply to: Not a IH but hopefully some ideas. posted by Wardner on January 18, 2011 at 14:29:44:
I thought so and did post, but got no replies. I am fairly sure that the 555 is the same as a 3610. I think the big problem I am running into is that I have 4x4. I can readily get a 2x4 pinion (I have one sitting in my garage) I cannot find a 4x4 one for the 3610. Did they make a 3610 4x4???? Even if I found one trough ford it would have to be ordered and I would hate to special order it and have it not work and be stuck with it as it is a $600 part.
Hopefully my contact can get the part from Escort in India. He says they found one, but we will see?
Clint
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
