I'm thinking there is some confusion on when this battery voltage is being read. A battery that reads 11.9 volts with no load on it, has not had a heavy load on it for at least a few minutes or so is basically a dead battery and will not crank an engine. Now if you are reading voltage while cranking that is a whole different situation. Anything over about 10.5 volts would be considered good cranking voltage. It boils down to open circuit voltage versus loaded voltage. Like pointed out, 12.6 volts on a battery that has not seen a charger for several hours would be considered as a full charged battery. If it has been on a charger, weather running in a vehicle or separate battery charger , the surface voltage would have to be removed by a light load for a minute or so and then allowed to settle out again. The old lead acid batterys were rated at 2.09 volts per cell,normally just rounded up to 2.1, however, the maintence free batteries will some times run a little higher as they may be lead calcium plates or some derivitive thereof. Next thing is if you have one bad cell that can throw off the total open circuit voltage to give erronous readings. Takes more than some one reading a voltmeter to determine condition, all reading must be interpeted. I have heard good things about the new type of battery testers on the market, but I understand they cost $600 or so for a good one. I use a carbon pile load tester along with good voltmeters and hydrometers for my work.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
