Posted by Wardner on January 19, 2011 at 23:21:40 from (4.154.249.38):
In Reply to: Wardner snowthrower posted by Bob on January 19, 2011 at 21:42:35:
Thanks for following up Bob.
There is a minimum RPM on the fan otherwise the chute will plug up. There is no limit on the high side, apart from destroying the snowblower. Higher speeds require more horsepower and result in a longer throw.
I found on the internet that a 20" fan needs 540 RPM. If hydraulically driven, that will require 4.9 cubic inches at 2000 PSI and adequate GPM. My friend has a motor with slightly more than that. Too slow. We installed a new 2.8" motor that I had and it was quicker but not fast enough.
I am suggesting that we use a larger pump and his motor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
