Re: c starts hard
Posted by El Toro on January 20, 2011 at 05:10:07 from (108.3.200.96):
In Reply to: c starts hard posted by jcwag on January 19, 2011 at 15:15:39:
You probably should do a tuneup with new plugs, wires, points and condenser. You should be starting the engine at an idle. If you have a mag make sure the impulse coupling is snapping when cranking as this gives a hotter spark. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
