Re: Hydraulic system design exspert, question.
Posted by D Slater on January 20, 2011 at 06:28:08 from (184.15.34.211):
In Reply to: Re: Hydraulic system design exspert, question. posted by Owen Aaland on January 19, 2011 at 22:51:52:
Lots of good points, sounds like some rework. I would have to return oil at the suction opening, don't want that or at the one inch top line. would still be a problem if oil level droped to low I think. Do have a 3/4 inch opening pluged where the control lever went near the top of the liftall housing. Problem is I used a 11 inch clutch liftall with a 12 inch clutch. Don't know if you can see in the picture, made up 5/8 inch spacers to drop housing down to clear since I wasn't using the side openings. Would have to make hole in the center housing bigger to use the side opening or drop housing back out and rework. Already cleaned it after screwing fittings in to make sure no metal was dislodged before installing the cover plate. Oh well.
Another question on a 400 hydraulic system they returned oil above the fluid level. Only used them set to single acting with a small cylinder myself. Do they blow oil out the vent with bigger single acting cylinders?
