Re: BACKFIREING
Posted by old on January 20, 2011 at 11:05:56 from (4.245.13.148):
In Reply to: BACKFIREING posted by JEFF NC on January 20, 2011 at 10:27:48:
A back fire like that a lot of times is caused by the engine running way to lean. #1 check and clean the air cleaner and make sure it has good oil in it etc. #2 open up the main jet a little at a time to see if that helps. One way to double check this is to coke it some and if when you choke it some it stops you know 100% sure it is running lean
