Re: BACKFIREING
Posted by cody bodiford on January 20, 2011 at 11:10:45 from (76.1.121.1):
In Reply to: BACKFIREING posted by JEFF NC on January 20, 2011 at 10:27:48:
hayy buddy i have seen before a push rod bein bent or lifter stuck and it has happend to me so that would be a place to check you have already checked the carb wire and aircleaner.....have any questions just email me at bodifordcat@gmail.com
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
