Re: Farmall H PTO troubles
Posted by Bob M on January 20, 2011 at 11:36:07 from (67.240.171.41):
In Reply to: Farmall H PTO troubles posted by Eric in NE on January 20, 2011 at 10:50:48:
I agree with the others - the rear end has a couple gallons of water where gear oil should be and it's now frozen solid. This both locks up the transmission (specifically the countershaft gear set) and freezes the PTO shifter clutch in place.
You need to warm up the rear end long enough to melt the water, then remove the rear end plug to drain it out. Be sure to refill the tranny with gear oil afterward!
