It has been a while but I think you pretty much have to pull the rocker assembly to pull the head off but after you have the head off there is no reason you could not bolt it back on hand tight would be all that was needed to keep things together. Also if your just going to let it sit that way I would put a bunch of ATF in the cylinders and lay the head back on just to keep it clean, But if it was me I would leave it together till you have the $$ then open it up. I would still fill the cylinders with ATF and make sure the radiator and block are drained
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
