Re: Farmall A: can I pull head w/out removing rockers???
Posted by glennster on January 20, 2011 at 12:52:46 from (76.223.251.130):
In Reply to: Farmall A: can I pull head w/out removing rockers??? posted by DennisT on January 20, 2011 at 12:10:06:
i would drop the oil pan and see what sleeve is leaking. if you are getting coolant in the cylinder, i would suspect either a cracked cylinder, bad head gasket or cracked head. if the o ring is leaking, it would generally leak into the oil pan, not fill the cylinder. when you pulled the spark plugs, you should know what cylinder had anti freeze in it. been a while since i overhauled that engine, iif i remember, the head holds the top of the sleeve in, and the head gasket helps to seal the top of the sleeve.
