There is some information out there that would lead one to believe the Hs, Ms, 300s, 450s, etc. do all use the same hub, and even the I.H. parts books do show that the same hub COULD be used on both the H and the M, but I have never yet seen an M that does have the same hub as an H, so yes, you do need to find a hub from an H, 300, 350.
Hopefully you do not plan to install a loader on that 400? The spindles probably will not hold up if you do.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
