Re: 330 340 Utility hydraulics
Posted by tesmith66 on January 21, 2011 at 03:21:25 from (130.76.96.152):
In Reply to: 330 340 Utility hydraulics posted by Heat Houser on January 20, 2011 at 18:24:39:
Those valves are easy to repair, just hard to get off of the tractor. You will need a strong helper or a hoist to get them off of the tractor and on the bench, but then its easy. As far as I know, all of the parts are still available, as those valves were used on many different models before and after the 340. They are all simply squeezed together by some long bolts and sealed with o-rings and gaskets. take them apart, replace the o-rings and gaskets (and any of the hard pats that are worn out or broke) and put it all back together. Be careful, though- it's a heavy assembly.
Funny thing, I'm an N guy myself. Have a 2N and a 340U. Those 340 parts are a lot heavier than the N ones :)
