Re: Which plugs in an M and needle valve question
Posted by soybeanjoe on January 21, 2011 at 05:36:11 from (66.213.171.108):
In Reply to: Which plugs in an M and needle valve question posted by Baelee05 on January 21, 2011 at 04:22:35:
The needle valve problem you are experiencing isn't uncommon. Buy a CIH needle valve & seat seems to help but still isn't a cure-all. I've had brand new ones cause problems. If you get one that works for very long feel fortunate. I think it is a combination of the vicon used on the tip & today's unlead / ethanol gas.You might try adding some lead substitute to your gas, may or maynot help. We've just gotten to the point where we shut the gas off at the sediment bulb housing whenever we shut the engine off. PIA if your using your tractor much but it works.
As for the plugs, I gave up on Champions about 5 years ago and switched to Autolite after running Champions for over 50 yrs. 386s seem to be the most recomended but I still had some fouling issues with them so called Autolite. The tech I talked to recomended 3116s for the IH 4 cylinder engines, said 386s were for the 6 cylindwer engines. Since switching to the 3116s we have had any problems with plug fouling. I have an M, 2 SMs & a SMTA. The tractors are "toys, don't use them to farm with other than on augers unloading corn & beans from bins
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
