Re: Which plugs in an M and needle valve question
Posted by rustyfarmall on January 21, 2011 at 05:46:35 from (209.152.78.140):
In Reply to: Which plugs in an M and needle valve question posted by El Toro on January 21, 2011 at 04:22:35:
I've found that needle valves, and the seats, have a residue on them left over from the manufacturing process. If you spray both pieces generously with aerosol carb cleaner before you install them, you will not experience any sticking problems. If you want to take it one step further, spay a little silicon spray lube on both pieces after you use the carb cleaner and both pieces are dry.
Autolite 388s are the pluf of choice for a tractor that sees very little use, unless that tractor has a magneto, and then you want to use the Autolite 3116s.
