Re: Which plugs in an M and needle valve question
Posted by pete 23 on January 21, 2011 at 09:06:25 from (173.87.15.134):
In Reply to: Which plugs in an M and needle valve question posted by Baelee05 on January 21, 2011 at 04:22:35:
Switching brands of plugs will do little , it is all about type and heat range of plugs. I always use champion, have for 55 years. A little lube on the tip of that needle valve may well solve your problem. A viton tip will always hold better than steel with less pressure from float. That is why they changed to them. IH 4 and 560's with their larger fuel tanks put a little more pressure on the needle valve than previous models and all the carbs leaked brand new so IH went to viton tip. Problem with the new one is quality control. The hole in seat is often times oblong and needs to be coined to work well.
Does ethanol affect them,possibly as I have found that it will harden the rubber hoses used on fuel lines in a year or two of use.
