Re: wheels turned in or out?
Posted by pete 23 on January 21, 2011 at 09:37:15 from (173.87.15.134):
In Reply to: wheels turned in or out? posted by brian1855 on January 20, 2011 at 19:31:34:
Wheels turned out allows you to have hub clamped closer to housing and somewhat less strain on axle. And then most feel they look better turned out as I do, but there is no set way, what ever you like.
