Re: W-400 Block repair sleeve availability
Posted by D Slater on January 21, 2011 at 14:03:04 from (184.15.34.211):
In Reply to: W-400 Block repair sleeve availability posted by Red John 2 on January 21, 2011 at 10:51:28:
Its not uncommon to have them repaired like that. The Machine shop I used to use had a list and sizes of repair sleeves to chose from. They bored the block for a press fit of the repair sleeve OD, then bored the ID for the original sleeve fit if wanted. If the crack is above the bottom of the cylinder. Leave a ledge at the bottom of cylinder for the repair sleeve to bottom out on.
