Posted by OregonDoug on January 21, 2011 at 16:31:27 from (67.142.164.21):
In have a 1965 IH 606 that came with the drawbar system off the tractor. It has a flat bar with pre-drilled holes that fits between the lift arms of the 3 point in a perpendicular fashion to the PTO that I can add clevis pins, tow balls etc but it rotates in the 3 pt arms. there is another "drawbar" that appears to attach up under the transmission and then lay across a perpendicular frame about under the PTO shaht. It also has what appears to be a quick attach system in a bell type coupler under the transmisson that I assumed the end of the drawbar went into. The trouble is I can not get the end of the drawbar in the bell coupler at all and the pin does not go up to allow it even if I could get it in. Is there a release on the pin to allow for attachment and is it where the forward end of the drawbar is supposed to attach in the first place? Hate asking a dumb question but I just do not understand what this is supposed to look like. Thanks in advance. Doug
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
