Re: 46ish H hydraulic fluid capacity?
Posted by Janicholson on January 22, 2011 at 04:58:14 from (67.72.98.45):
In Reply to: 46ish H hydraulic fluid capacity? posted by chrisr8n on January 22, 2011 at 04:26:40:
6 qts. Assumes all 2 way cylinders are full. Cycle the cylinders until they work correctly while checking the fluid in the system. The level will be fine between 7 and 8 inches down from the top of the fill pipe stand pipe (original nipple length if hardware is added to the top) Jim
