Posted by Janicholson on January 22, 2011 at 05:20:58 from (67.72.98.45):
In Reply to: cold start posted by Farmallzach on January 21, 2011 at 18:31:36:
two ideas not mentioned. A engine block heater (either placed in one of the core plugs, (often called freeze plugs but are not)is great. Also if it is point and coil ignition, a jump battery that just supplies ignition voltage. Leave the ignition off, and jump to the coil for starting. (if 12volt, it may have a ballast resistor. for starting it can be bypassed.) Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
