Re: C.G. of an M?
Posted by Bob M on January 22, 2011 at 07:03:52 from (67.240.171.41):
In Reply to: C.G. of an M? posted by CenTex Farmall on January 21, 2011 at 19:37:27:
If you have access to a platform scale, CG for your tractor is simple to determine:
1 - Measure the wheelbase - ie. the distance between front and rear axle centerlines. (For an M it should be 94")
2 - Scale/record the weight on the front and rear axles.
3 - Calculate CG location:
weight front axle / total tractor weight x wheelbase
The result is the distance CG is ahead of the REAR axle.
Example: You scale 2,000# front, 3,000# rear (hence total tractor weight = 5,000#) and WB is 94":
2,000 / 5,000 x 94 = 37.6
CG then is 37.6" ahead of rear axle centerline.
