Re: cold start
Posted by glennster on January 22, 2011 at 09:12:37 from (99.90.9.153):
In Reply to: cold start posted by Farmallzach on January 21, 2011 at 18:31:36:
i picked up a propane radiant heater from menards, it mounts to the top of a gas grille tank. put it under the tractor so the heat flows up to the carb/intake area. i lean a piece of plywood off the loader frame to the hood to hold the heat in a little better. works good on my 48 m with a loader, the tractor is prolly the slowest cranking m i have ever seen. new battery, new cables, 3 different rebuilt starters, even swapped starters from another m that cranks fast. no difference. prolly has big pistons and a shaved head on it.
