Re: Which clutch do I use?
Posted by rustred on January 22, 2011 at 09:51:53 from (74.200.18.155):
In Reply to: Which clutch do I use? posted by 41106 on January 22, 2011 at 09:24:08:
biggest thing is how hard your going to work the tractor. nowadays these old tractors dont see the work they used to. using the 11" clutch will be quite sufficient for yard work. unless its going in the old tractor pulls , then i agree that the 12" is a better option. i put a super engine a W-6 and used the 11" and its just fine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
