Re: Which clutch do I use?
Posted by 41106 on January 22, 2011 at 16:23:07 from (4.229.195.193):
In Reply to: Which clutch do I use? posted by 41106 on January 22, 2011 at 09:24:08:
I have a 400 pressure plate that is nearly new. The belly pump and belt pulley have been removed. Could you explain in terms a rookie can understand what needs to be done to use the 400 pressure plate. Comparing the 2 of them, the M pressure plate has 3 arms that go against the throw out bearing and the 400 has a spined center. Any advice you can offer is very appreciated. If I don't have to buy a new pressure plate that would be great!
