Re: cub with ignitor system
Posted by El Toro on January 23, 2011 at 04:22:11 from (108.3.200.96):
In Reply to: cub with ignitor system posted by jeep258goat on January 22, 2011 at 20:00:24:
If you pulled the distributor and didn't note where the rotor was pointing you probably have your engine out of time.
You need to pull No1 sparkplug near the radiator and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while a helper slowly hand cranks the engine until you feel compression against your thumb. Have the helper keep cranking while you feel for compression. When No1 piston is at tdc pull the distributor and rotate the rotor to the No1 plug tower and reinstall it. Hal
